Perhaps the best analogy I can come up with is that 1084 is the AK-47 of blade steel. It is the solid performer in most general applications for the average man who doesnt want to have to be an expert in tending to special considerations. It is hard for too many things to go wrong with 1084. However...
There are shotguns that pack more close range wallop, pistols that are more portable, and sniper rifles that are very much more accurate. 1095, W1, O1, 52100 or W2 properly heat treated should be able to easily outlast 1084 in wear resistance and edge hold that benefits from the same. 5160, L6, 15n20 and some S series with proper heat treatment should have little problem handling many times more impact force than 1084. If you want a pretty good edge holder that can do some chopping as well and you want to heat treat it by eye... yep 1084.
I myself have pushed 1084 hard for folks with limited heat treating equipment but I would not want to create yet another ultimate steel myth in the process of recommending a trouble free steel. I believe 1084 should be the easiest steel to get a really good knife from without much hassle, but the same is even more true of many other steels if you know exactly what you want and have the means to get it.
