Has yours been used much? Reason I ask is that mine will take a slight hollow even if I am somewhat careful to use the whole stone. I believe these stones are known to have a very strong outer layer and once you cut through that they release abrasive far more readily.
I don't have any problems with glazing with mine, I honestly am wondering if it is too weak of a bond for my uses sometimes. I can't really tell if the massive amount of debris formed is the stone shedding or simply steel filings.
Correction....I believe my stone is NOT the "II" series, but rather just "Sigma Power Ceramic Stone #120". I did notice the hard shell, too. No, I haven't use it a whole lot, several new knives/bevel sets/sharpenings. I think the hard layer has been removed for the most part, so it is possible that the stone may dish faster now. I said load earlier, but maybe glazing is more correct term? It doesn't seem to release grit at all, doesn't seem to dish much (comparatively speaking against like a Crystolon). Reading the suggested use by "Schtoo...Tools from Japan"....I use it under running water. Most knives I make are carbon steel....you see my problem in using the stone*. It REALLY does need to be used under running water, otherwise, it WILL glaze over. The only way to treat that stone once it's glazed is by loose SiC powder, CBN powder, or diamond powder (not taking an expensive diamond plate to that cheap stone). They say to use 36 grit SiC powder. It came with 60 and 120 grit....which even the 60 does not seem to refresh the stone all that well. The 36 grit might...I need to get some (stone SHOULD have come with 36 grit instead of 60 and 120). I can't imagine the stone I have shedding grit at all. I've only used one side, leaving the other as reference. After several sharpening sessions/conditioning with the SiC powder, it is much finer than the non used side. I would prefer a looser bond, really, on this stone. It's "cheap" enough to experiment with. Want a coarse, clean, apex? This would be a good choice for that.
*Especially new custom knives, I want the edge bevel to be perfect, so I use the Razor Edge Systems guides, with blue painters tape to prevent marring the blade polish....water here is a problem.
FortyTwoBlades, my apologies for any thread derail. I'll be glad to delete and move to new post if requested. I appreciate your posts/products. Headed to your store now...
....and order placed for the MantiCore and Bull Thistle stones! Exciting!!!
