OK, I know that I am beating a dead horse, but I would like some advice on my 2x72 grinder setup.
First some background-I've always loved knives and started making them this past winter as a way to pass the time. I was hooked almost instantly and ordered an Oregon Blade Maker Chassis, that has been sitting in my garage still in the box, I'm still using files and sandpaper, though I did purchase a HF 1x30, which I've used a couple times and now only use to help round outside radii. I've decided to get the OBM setup. Currently, I'm working in a corner of my garage. I do not have 220V available, nor do I want to run a new circuit as we will be moving in the next year. I have no time at the moment to learn to forge, so I'm doing strictly stock removal. I mainly work on EDC and hunter type knives, with the occasional kitchen knife thrown in to keep the missus calm. That said, I've come up with 4 options to get my grinder set up. My budget being ~$600 or less.
Option 1-direct drive, single speed. With either a Harbor Freight or Iron Horse 1hp motor. I know that this would be the absolute cheapest and easiest way of doing things, but also the most limited with getting my full capabilities from the grinder.
Option 2-direct drive, with the 2-speed wheel setup from OBM (http://www.ebay.com/itm/Belt-Grinde...ing-grinder-/252181568509?hash=item3ab7315bfd). Again, using either a HF or IH motor. I would still be limited in options with speed, but I could have one faster for stock removal and one slower but with more torque for post-heat treat and other times when slower speed or higher torque would be better.
Option 3-direct drive, with a 1hp 3 phase Iron Horse hooked up to a KBAC-24. This would give me limitless control and a 3/4 hp output.
Option 4-direct drive, KBAC-27D with Leeson 2hp motor. (http://www.ebay.com/itm/KB-Electron...239518?hash=item46613f275e:g:ImsAAOSwUKxYildU). This would again give me limitless speed control and plenty of power. It's also a bit more then I was originally looking to spend.
I already assume that everyone will be telling me to just go with option 4, the KBAC-27 and leeson 2hp. I guess my question is 'why?' I've read several threads that people have said that they leave there VFD on the same speed. So would option 2, the 2 speed wheel, be viable? Would it be helpful to have the extra torque at low speeds? With the money that I save I could invest some good, high quality belts, and be not only making knives but also learning to grind. I could also put purchase a couple more tooling arms and some small and large contact wheels. I wouldn't have that option with the KBAC-27.
When we move, I am planning on setting up a better 'shop' and for sure run 220 power at that time. If I went with option 2, I would upgrade my setup then as well, and would most likely use the extra motor to build a 12" disc sander.
Again, I know that most, if not all, will tell me to go the KBAC-27 route, but is it really necessary? Or would have lower speeds but higher torque be better?
Thanks in advance.
Thanks in advance.
