- Apr 8, 2016
Testing:
Results:
BEARINGS vs. WASHERS
Pivot Contaminant Test
1. Rexford Gamma (bearings)
2. CRK Sebenza 25 (washers)
3. Shirogorov Hati (washers)
Posted with permission from the source:
Source: https://www.instagram.com/p/BUwgCQPhufD/
Comments from IG post...
This has been something long discussed but never tested. So here you go.
Results:
[*]illudiumknightMy theory has always been that bearings would perform as well if not better than washers in handling contamination. The issue has been maintenance on loose ball bearings. But maintenance on caged bearings is just as easy as on washers
[*]tactikaoTested with the gamma
[*]illudiumknightI did not have to take apart the Gamma to get it back to original flipping action. Running it under warm water was enough. Both the Seb and the Hati had to be disassembled to be cleaned back to original action
[*]snecxInteresting observations! It's always easier to get bearings to run smoother, but I'm surprised contaminants didn't get stuck inside the bearing cages.
[*]illudiumknightEven if bearing balls were to be contaminated to the point of not moving, they would still act as a washer. Blade will not seize! Bearings give stand off space to move debris out of way, and space for cleaning without disassembly.
