Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Some folks have asked just how this is done, well I found one little bit of scrap soft leather that I could make this little tutorial up with, our friend John M Cohea is sending me some soft leather, really appreciate that to John!
A tip, you will need SOFT supple leather, not the kind you would normally use to make a sheath with, but something like deer skin, or Elk or Buffalo makes for a nice soft strong leather fob
First you slice a piece of leather that will fit into the thong hole of the knife using a ruler to keep the piece from moving, slice one side straight and then slide the ruler back to the proper width and slide while pressing down firmly on the ruler to keep the leather from moving on you.
Then slip the piece through the thong hole so you have equal parts on either side, take a sharp knife, I like the wharncliff for this for it's direct point and make two slits, each about as long as the leather is wide and spaced about that same distance apart, like this;
leather_braid_1 by GaryWGraley, on Flickr
then push one end through that first hole
leather_braid_2 by GaryWGraley, on Flickr
then pull the leather snug up to the knife, you want to make it so the fob won't slide around in front of the blade
leather_braid_3 by GaryWGraley, on Flickr
with that up as tight as you want it to be, doesn't have to be tight tight, as you do want it to pivot a little bit, just not a big loop, then on the other side you will also cut in two slits, like you did on the previous piece;
leather_braid_4 by GaryWGraley, on Flickr
and now we just alternate, insert the other leg into the newly made slit
leather_braid_5 by GaryWGraley, on Flickr
and then put the other one through the other leg, part of that braiding thing...
leather_braid_6 by GaryWGraley, on Flickr
until you end up with both 'good' or finished sides of the leather to the outside I then take and roll the braid between my thumb and index finger, rolling it to make it a bit smoother fitting
leather_braid_7 by GaryWGraley, on Flickr
next post for the bead part, limit of 10 images per post...
Edited to add this link to a paracord lanyard fob tutorial
leather_braid_1 by GaryWGraley, on Flickrthen push one end through that first hole
leather_braid_2 by GaryWGraley, on Flickrthen pull the leather snug up to the knife, you want to make it so the fob won't slide around in front of the blade
leather_braid_3 by GaryWGraley, on Flickrwith that up as tight as you want it to be, doesn't have to be tight tight, as you do want it to pivot a little bit, just not a big loop, then on the other side you will also cut in two slits, like you did on the previous piece;
leather_braid_4 by GaryWGraley, on Flickrand now we just alternate, insert the other leg into the newly made slit
leather_braid_5 by GaryWGraley, on Flickrand then put the other one through the other leg, part of that braiding thing...
leather_braid_6 by GaryWGraley, on Flickruntil you end up with both 'good' or finished sides of the leather to the outside I then take and roll the braid between my thumb and index finger, rolling it to make it a bit smoother fitting
leather_braid_7 by GaryWGraley, on Flickrnext post for the bead part, limit of 10 images per post...
