- Mar 15, 2010
At first I had a great idea for a longish review on this knife, but I'm tired and not feeling up to it. So, here's a short sweet review that I'll break down into things I like and don't about the Vantage Pro.
-The G10 handle scales are nicely done. They are slightly polished, but not shiny. They still provide good grip even though they aren't highly textured.
-The pocket clip is done really well. It holds tight and rides low. It also doesn't tear up pockets thanks to the smooth G10. It's mounted securely via two T6 torx screws on the butt end of the handle.
- The blade shape and finish is great. I love the belly and nice, thin hollow grind. The finish is unlike any other I've seen. It's kind of a satin finish but has an almost stonewash to it. I tried to capture it in pictures, but it did not show.
-The blade steel is another great aspect of the Vantage Pro. The Bos heat treated S30V is good stuff. It came nicely sharp and has held a really good edge through the 2 weeks of fairly hard cutting tasks. It seems like it may be on the harder end compared to the S30V I'm used to (various Spyderco models).
-The lockup is solid with no play in any direction.
-The action is nice and smooth (no pics here).
Dislikes:
-The fit of the scales is a bit off in places.
Here, you can see the left scale isn't flush with the liner. Also, you can see the centering, which is a hair off centered.
-The flipper doesn't work as well as I would like. I'm not sure if it's the positioning or the size of the flipper. Perhaps a combination of the both. Although, with a slight "flip" of the wrist, the flipper does work.
-The thumb hole is a bit occluded by the scale. It's definitely workable, but not optimum. If it were a round hole, a la Spyderco, it may not be a problem. But, the oval shaped hole makes for a bit harder deployment.
-The weight is a bit more than I expected. By my hand scale, it's about the same weight as a sprint run Manix. It's definitely heavier than a Para Military 2. This isn't totally a dislike, because the knife actually carries well. But, it's something to consider. I may try to mill out the liners a bit to shave off a bit of weight.
All in all, I really like this knife. It may not be perfect, but it does a lot right. The pros most definitely outweigh the cons. I would recommend the Vantage Pro for anyone who wants to try out S30V on a budget. If you do some searching, you can get one for around $50 + shipping. I got mine for quite a bit cheaper, though.
Thanks for reading. I know I said it would be short, but it turned out to be a bit longer than I expected.:foot:
Dislikes:
