I am planning on building a folder up to now worked on fixed blade models. I am somewhat unsure as to how the use of flat head or button head bolt are used to hold the scales on. For example if you use them from one side the are tapped into the tang (liner) how do you get the other side lined up so they are in the same spot . Also can you use them on a fixed blade knife, if so do you offset the bolts as you have to tap the tang in the same spot to utilize the bolts? Hope I explanied this correctly. many thanks in advance
thor
thor
