- Jul 23, 2007
Any chance of a 3V version as well ? Delta 3V is probably much more corosion resistant than 4V. Since I plan to use it mostly to clear 4 wheeler trails extra corrosion resistance would be a big plus...
Don't conflate me with speaking for CPK here but I really don't think you will want to use a Bladesport Chopper to clear a trail.
It's made to be used carefully by a skilled hand on known tasks.
Its likely to be more fragile than the RLC and the RLC can be damaged by a wayward cut.
I wouldn't suggest you take a F1 car down a road with potholes to pick up groceries.
Very encouraging news regarding the Medium Chopper pattern as a main staple just because with about a dozen or so BCs in the forecast, there will most likely be some broken hearts! Will the CPK-MC be slightly longer than the LC, apart from coming in at both heftier and beefier?
What will be different about the handle, length, swell? I wouldn't mind a handle about a half inch shorter than on the light chopper.It will be a hair longer, around .215 stock thickness, a little bit different handle. I'm planning a batch of about 40 to start.
Another one?!!
Shit.
With empty wallets?You know how we roll
With empty wallets?
Haha!
I told myself I only needed one chopper.
Needs...Wants... they all look so similar.
Don't forget the light Chopper-Great Knife and very LightweightMan.. you guys are getting in my head..
I grew up using a pocket knife and a hatchet for everything in the woods. Then as I got a little older I switched to 3-4 inch fixed blades and a hatchet. Now I carry a 3-4 inch fixed blade and a 19-26 inch axe.
You guys are making me think I could get by without the axe if I had me a choppin' knife. Suddenly I want a MC or HC.. I never really considered it. I'm an axe guy.. or at least I am for now..
Guess I'll have to give it a whirl.
