CPK Mark
- May 24, 2017
I've had lots of inquiries about the folder I debuted at Blade this year. I apologize for just now getting the information to you guys, but Nathan doesn't let me off my chain too often.
The main questions have been specs on materials and dimensions.
OAL is 9.5. It is a substantial knife.
Blades are cpm 3v and mic out around .215 (nice and thick). Of course they were heat treated at the CPK compound so we all know what that means. I hollow ground these blades on my Burr King with a 10" wheel for the primary grinds and an 8" wheel for the top grinds. Did a few compound grinds as well. Prototypes were sharpened at 22.5 degrees.
The Frame and lockside are constructed from 6al4v knifemakers grade titanium. This stuff is well worth it's higher cost. It is flat and free from surface imperfections. I love it.
Both frame and lock mic out at .204. The lockside also utilizes a D2 tool steel insert (HRC56) that interfaces the locking tang on the blade. The insert has a 5 degree angle while the blade uses 7 degrees. This insures the proverbial "bank vault" lockup while making disengagement a breeze. The insert also has a tab integrated that fits a machined slot to make it impossible to overspring the lock.
For the action, I've utilized an AKS .250 pivot and bearing system, also using their thrust washers. For this knife, it is my opinion that this is the finest system available. Very tight tolerances. The original prototypes used (.0625) 52100 detent balls. The later protos use ceramic as will any possible future runs.
The backspacer is solid g10 that is handlapped on a surface plate to match the blade and counterbore math.
Finally, the pocket clip is machined from a billet piece of 6al4v titanium that uses a ball-bearing to retain the knife in your pocket. Holds it tight but doesn't make it impossible to remove.
I'm sure I've forgotten some things but I'm tired. I will also post pics of parts as well as comparasion pics with other folders. Thanks for your time
