Originally posted by Frank Niro
Well it may not be much but here is a start for you. Cobalt is often added to "regular steel drilling" bits. It does improve cutting abilty considerably. The common amount of cobalt added is usually 8%. Silicon carbide can be a great cutter but is very brittle and is used in bits to drill very hard steels and also in masonary bits. The silicon carbibe bits are usually at least twice or more the cost of regular bits. Lots of care and good cutting fluids with reduced drilling speeds should be used with a reasonable, and controlled amount of pressure. Silicon carbibe drill bits in "true" fractional and numbered sizes also not commonly available. However, properly used in the applications necessary silicon carbide bits will drill very accurate holes. Frank Niro
Tungsten carbide is a type of steel mainly comprising of cobalt as well as tungsten carbide. The cobalt will act as a binder and help enhance shock resistance when drilling. The shock resistance provided will depend on the percentage of cobalt used to manufacture the product, and usually a small amount of wax will be added to hold the materials together. Tungsten carbide is a high-strength material and has a compression strength greater than many forged metals and alloys. This type of steel has a tensile strength ranging from 100,000 to 500,000 PSI.
