I guess that's true. Here's hoping mine goes out today.
FYI: The phone number on your website is no good. The operator says its been disconnected.
Are you sure you dialed correctly?
Quite sure.
That would make this situation a LOT better.
Don't take the time to change the production versions. Just ship them with the smaller pin and let us change it if we want.
+1 .. :thumbup:Quite sure.
OK, as far as the "stop pin fix" goes.... and please correct me if I am wrong.
In the closed position the ball detent rests in a hole in the blade.
If you use a smaller stop pin the detent ball will no longer rest in this hole, it will go past it.
Thus, no longer providing a firm detent index in the closed position; as it came from the factory.
This is in addition to the "later" lock engagement that has has already been mentioned.
Did you find this to be true 'Whitty'???
Not complaining or griping here.... just throwing out the thought.
That is a nice fix as long as the pin does not rotate. :thumbup:Here are some more pics to show how simple this blade alignment fix is. I removed the 3 T6 screws, & the pivot screw only. I then lightly pried apart the G-10 scale and left the rest of the knife together. The stop pin came out still attached to the G-10 scale. I simply ground a flat area where the blade rests when closed. Do not grind to much or the blade will close to far and hit the backspacer. This left the open lock position unaffected and still properly adjusted.
The detent to keep the knife closed is actually a little tighter now and more secure. The knife still easily flips open. The actual adjustment & disassembly took less time than writing this & taking pictures.
This knife is just too nice to let everyone lose hope in it after just a couple days.
JTC3495
Do you work in a body shop? I like your: "this is America.. we fix things" attitude. But we will take care of anything you want done.
That is the exact blade position. Give me an update after you had a chance to work it.
Give me your tshirt size and knife number on a PM. I will shoot you an oil rag in training.
Good observational skills...... :thumbup: ..JTC3495
