If it were for me, I'd choose the best corrosion resistance over the best wear resistance because of how I use it. I basically only use it a couple times a year, and sharpen it before the trip and forget about it until the next trip. So I think Nitro-V would make a nice one for me personally. Also, I'm usually a terrible fisherman so wear resistance has never been a problem
my order is XHP cpm154 aebl
XHP can be run (with cryo) all day at rc63 with no chippig issues less abused. cpm154 at rc62 is going to hold an edge about the same as XHP (to most users ) but it will also have ever so slightly more toothy edge (not much more ) in add aebl only by reputation as i have never used it never needed to. i am unsure if s35v gives much advantage over the others when you count into equation of is the user going to be the one sharpening (do they have DMT stones ?)
I'd be worried about breakage. I haven't done a knife out of it (yet) but I've dealt with it some in the form of machining toolbits. At least the stellite I've seen isn't the most ductile. Sorta halfway between hss and tungsten carbideWhat about Stellite 6k? Not exactly a steel but it is extremely corrosion resistant.
I wouldn't be worried about breakage. Phil Wilson has made filet knives from really hard steels (S90V & 10V IIRC), and although they have the perfect everything it goes to show it won't break. Also machining tool wear is different than cutting an animal up.I'd be worried about breakage. I haven't done a knife out of it (yet) but I've dealt with it some in the form of machining toolbits. At least the stellite I've seen isn't the most ductile. Sorta halfway between hss and tungsten carbide
Alpha knife supply (at least used to) sell it. I haven't looked in a while though. I've been wanting to get a few bars for some bird and trout's for a whileCan you even get a bar of Stellite anywhere?
