JuJu-
- Jun 7, 2011
Well sir, being Irish I know that Irish moss is used as a thickener. It does nothing to enhance flavor.
Can't blame me for trying to pass beer ingredients as an enhancer, I tried!
Can someone who has handled this tell us if there is a detent hole cut in the blade to correspond to the detent ball on the frame lock?
Speed safe is cool, but simply removing the torsion bar to make it a manual flipper would probably be my preference.
i hope it is drilled for a detent and has bronze bushings if it does iam buying alot of these same with the new rj martin design one.
Hands on
The Thermite doesn't have a detent hole. It's SpeedSafe only.Does it have the divot in the blade for detent so the assist can be removed? And if so did you try it? Is it smooth without it?
I am sending mine back to kershaw tomorrow for a stripped torx screw head...:-(
I wouldn't say cheap screws, just wayyy to much Loctite.Very common. They used way to much loctite and some really cheap scews. I'm taking both my Thermite and Cryo 2 in this week.
I'm sure of that. That probably helps to keep the costs down.They are a less quality metal I can assure you, at least on the Thermite anyway.
After reading about the amount of Loctite on the Thermite and the Cryo II, I was worried about trying to move the pocket clips from tip-down to tip-up. I got the soldering iron out and prepared to do battle. I inserted my Wiha torx bit and...they spun free! I didn't need to use the soldering iron at all. I looked and there was barely (if any) Loctite at all on the screws. Seems like the factory put all of my Loctite on your screws.
You got lucky! Rival stripped his wiha on his thermite
Wait a minuite, this knife is out now? It still says preorder everywhere I look? As far as the detent go's I'll just drill my own. This looks like a great inexpensive base knife to customize. Which for me will start with ditching the speedsafe. Not a fan
This knife in elmax or S35 or D2 would be sooooooooooo awesome.
