- Sep 16, 2015
I heat treated 1095 like I normally do in canola oil. First, I will show you what I know to be good results:
This is just a sand blasted finish. The fact that the edge is still shiny, means its harder then the glass beads I am using to blast it with.
Now on to the piece in question:
There are a few "shiny" spots that I know to be hard, but if you look close enough, there is a hamon on there. To me, it means some form of differential hardening happened. The gunk on the spine is still remnants of the clay
Here is a closer view:
A file slightly bites into it, but its not easy. Perhaps there is a harder layer just slightly under the surface?
Has this happened to anyone else?
