Hey guys, well I received the blade yesterday and cleaned it off by soaking it in brake fluid.
It shined up well and there were no bends or bad gouges, just normal sharpening marks and some scratches on the sides from use, plus almost zero rust!
This was the only identifier on the entire blade...any guesses?
Next step was to get my supplies together, a chunk of horn, epoxy, brass, torch, solder kit and head to the shop.
The next few hours are kinda a blur, I removed the old LaLa and cut the horn to size. After heating the tang to burn a spot in the horn, next came annealing the brass and cutting it into shape. I was trying to copy the Kami's style best I could, needless to say I came up a bit short! The biggest issue for me was the soldering, I really need to do a lot more practice on it but this was a great learning experience. After filling the horn with epoxy then filling and sanding down the extra bits I finally got to feel the balance
17" Overall, 27oz. with a 12.5" blade and 4.5" horn handle
The last thing I did was step off into the woods and take down a few dry Oak and Hickory limbs plus a Cedar or two. The edge geometry is really nice, it snicks right thru the small stuff and buries into the hard without getting wedged. A file did not touch the edge in the shop but could bite into the spine and after my little cutting test the edge showed no deformities or dulling!!!! The horn is real pretty but might be too slick for me, I figure buy the time this handle begins to fail I might be better a soldering and give it a new grip with wood. Thanks for taking the time to read this guys, hope you enjoyed it!
Take care,
Jim
