I received my clamp system for the Hapstone V6, and I gotta say, my initial problems with the V6 without the clamp are a distant memory. Don't get me wrong, there is some room for improvement, but this is a tank of a sharpener now.
So here goes:
Here are the specs:
- Compatibility: Hapstone V6, Hapstone Pro V5
- Sharpening angle range: from 13° to 45°
- Angle tolerance: 0.5°
- Maximum thickness of the knife spine: 6 mm
- Maximum blade length: 20 сm (8")
- Size: 17 x 20 x 18 cm (6½" x 8" x 7")
- Shipping size: 27 x 17.5 x 9 cm (15½" x 7" x 3½")
- Shipping weight: 1.6 kg (3.5 lbs)
- Materials: Stainless Steel
These specs aren't completely accurate.
- I was able to attain an 11deg. angle when sharpening my large kitchen knives, but only 15deg.'s when sharpening a Paramilitary 2 (more on that in a bit).
- Secondly, the only thing made out of stainless steel on my unit was the two screws that go in the bottom to hold it to the sharpening table. Everything else on this beast is high-carbon steel that I can literally stand and watch rust form. It appears to have some Cold Blue or some other product slathered on it, but it isn't very effective. I use a lot of water in my sharpening process so when I'm finished with my sharpening for the day, I wipe it down then soak it in Ballistol.
- It says .5deg. angle tolerance, but I found that it was closer to .1, which, considering my electronic angle gauge has a .2 margin of error, that's pretty darn accurate.
Here is a shot of my set up when sharpening one of my kitchen knives:
As you can see, I set this bevel at 12 deg.
When it comes to kitchen knives and large fixed blades, this clamp is excellent. The angle is dead on, and the sharpener is rock solid. You can adjust the tension of the rotating clamp, though I left mine on what they set to at the factory. You can feel it lock into place when the knife hits the horizontal and it stays there until you move it. It takes some force to do so, but I don't think I would loosen this any.
The solidness of this unit comes at a cost (other than $$$), and that is weight. With so much weight on the front of the sharpener, I found that it was front heavy and it was unstable. To counter this, I actually screwed it to my workbench, as you can see here:
Now on to pocket knives, the reason I bought this sharpener. I wanted a way to consistently sharpen my Paramilitary 2 rotation. I knew going into it that the clamp wasn't the ideal method for this, but figured with the quality of the materials I could modify it in some way.
Here is my first go at sharpening a folding knife. It's an Endura and as you can see I attached one clamp to the lock bar and the other to the blade.
This worked surprisingly well, but I knew this wasn't going to work for my PM 2's.
Hapstone tells you that you should use two clamps on one side for short bladed knives, and I tried it, but it just didn't work well. The reason this doesn't work well is that both clamps are on the one blade and the clamps interfere with the sharpening stone at low angles. The best I could manage was around 22 degrees. I'm not walking around with a 44-degree bevel; my ax isn't even at that!
So here was my first attempt at an alternate configuration:
I slipped one clamp into the frame of the knife and the other on the blade (using several layers of tape for protection). This worked to hold the knife, but I wasn't able to get a consistent angle from side to side because the blade wasn't perfectly horizontal. This isn't absolutely necessary, but I just felt there could be a better way.
And there was...
[REVIEW CONTINUED BELOW]
