Originally posted by Gollnick
Off hand, I can not think of any metal that truly does not rust at all.
The closest that you'll come to a truly non-rusting metal is Gold.
Originally posted by T. Erdelyi
why is it when I used a Buck Titanium Folder to hold a pistol target to a piece of plywood, I shot, missed the target ...
That's excellent information.
But, unfortunately, gold doesn't heat-treat well.
Originally posted by Quiet Storm
Sorry, I don't have anything worthwhile that hasn't been mentioned before to contribute to this discussion, but I just wanted to say thanks to Gollnick and fishbulb. Most interesting posts, guys!
While Auric Oxide (gold rust) can be created in the laboratory, it is never found in nature.
In order to make it you have to go through a complicated reaction involving several steps and many different chemicals. The resulting gold rust is inherently unstable and will readily decompose back into gold metal and oxygen gas.
So while you can indeed force gold to react with oxygen under certain odd conditions, it is naturally inclined to not rust and won't do so without some help from chemists. I suppose that depending on how you look at things it could be considered a non-oxidizing metal.
You can find some more details here.
Like stainless steels, it is dependent upon an oxide film for its corrosion resistance. Therefore, it performs best in oxidizing media such as hot nitric acid. The oxide film formed on titanium is more protective than that on stainless steel, and it often performs well in media that cause pitting and crevice corrosion in the latter (e.g., seawater, wet chlorine, organic chlorides).
