I've had a good experience regarding micro-bevels and different people's opinion of them. One opinion was of Murray Carter's. Due to his expertise and what he said I started thinking about the subject quite a bit. And I had already thought about it a lot. So here goes.
I've been working HARD on improving my sharpening skill for 2 or more years. Getting info from everyone I could and trying things I've learned a lot. And my edges are showing improvement. In that timeframe I've been putting a micro-bevel on about everything I sharpen. Except for paring knives which have a blade thin enough that one bevel is sometimes not as wide as some micro-bevels. One thing to consider is how big is a micro-bevel? I like to say micro when the bevel is barely visible to the naked eye. When it is easily seen I like to call it an edge bevel. Just two terms to indicate the size in addition to the fact that it is at a higher angle than the rest of what I would call the "edge" which is normally two angles for me. Edge bevel and back bevel. This seems to be how most people sharpen an edge on most knives. I'm saying that because Murray's terms are primary edge and secondary edge (or bevel). I sent him one of my knives to sharpen for free. First sharpening for free is an offer he makes to anyone who subscribes to his sharpening tips. I did have to pay $15 for return, insured shipping. The blade was M4 sharpened with a back bevel of about 12 dps and an edge bevel (easily seen) or around 17-18 dps. Before I sent it to him I touched up the edge on an 8k Shapton glass stone. It was as sharp as I have ever gotten a knife given my ability. One of those final touches that you try your very best. The reason I wanted to send him a knife to sharpen was so I could see/feel/use an edge sharpened by someone other than me. No one I know sharpens better than I do. Do you know why? I don't have any friends (in-person friends
) who are into knives.
Anyway, when he got the knife he replied that I had a micro-bevel on an otherwise well sharpened and polished PRIMARY EDGE. Then he said that a micro-bevel degrades cutting performance. READ IT AGAIN if you missed it. Degrades. Makes worse. Isn't as good. I was very surprised he said that. I had no idea anyone would feel this way. Especially someone of his experience and skill with all aspects of knives. But to actually understand why he feels this way we need to look at the way he refers to the edge and blade. The knife I sent him was a FFG blade that is thin at the edge. So, from edge to spine I use the terms edge-bevel, back-bevel then full-flat grind. Mr. Carter's terms are primary edge (with a micro-bevel) and secondary bevel. He refers to the Full-Flat Grind as the secondary bevel. So in his opinion the micro-bevel degrades the cutting performance of the PRIMARY edge. So, if I understand him correctly he would only put one bevel on the edge of this FFG knife blade giving him a primary and secondary angle. Not two angles then the blade grind. I looked at the specs on a knife of his I love. One of the specs is called SECONDARY: This he calls FLAT. The knife has a FFG blade by the description most people I've encountered use. Ok. Now that I understands his terms I agree with him that a micro-bevel degrades cutting performance. But, by the terms I have learned to use I was calling my micro-bevel the primary edge. The rest of the edge (polished part) I called the back-bevel. The rest of the blade is grind by my thinking. The moral of this experience is I started thinking "why use a micro-bevel or any very small edge bevel on a knife edge? Why not just continue sharpening the lower angle until the bevels meet (apex) forming a sharp edge"? Below are what I came up with. The reasons are the same as many people already have and nothing new. But for anyone pretty new to sharpening knives it may help as well as convey (to all) how differently different people think about an edge as well as how differently they use words, terms and phrases to talk about them. Using different terms is confusing when on forums because of different backgrounds, even languages we may speak. Some people even use translators on the pc because they don't speak english at all. No telling what a computer translator will do with words.
My thoughts on when and why to use a micro-bevel: My opinion only and no better than anyone's.
First, and the one thing that will never change. The thinner a blade and lower an edge angle the better the knife will cut. Fact as far as I know. However, some uses for a knife demand a stronger, thicker blade and a higher edge angle. This is where the variations come in to play.
The very edge (apex) angle needs to be high enough that it won't chip, fold, etc. when used as the knife is intended to be used. Doesn't matter what you call it. Primary edge. Edge angle. Micro-bevel. Doesn't matter what we call it.
Above the first angle is the rest of the blade. Maybe it's a FFG. Maybe it's a hollow grind, saber, etc. For simplicity let's assume it's a FFG blade. After you have established an edge angle (primary) if the blade is very thin at the edge you may not need an additional lower angle which I would call a back bevel. Secondary bevel is probably the most common term. Not sure. If the blade is thicker than needed for the cutting I'm planning on doing with the knife I will put another bevel at a lower angle above the edge (primary) angle. This back bevel is only to "thin" the blade. Why? Because a thinner blade cuts better, no matter what. Unless it breaks because it's too thin.
So when re-profiling an edge my plan would be to decide the primary edge angle that will be as low as possible and still hold up to the tasks planned for that knife. After that I would decide on putting a lower angle back-bevel on the knife or not. This decision is based on the thickness of the blade and the intended use. Anything further will be determined per knife by me as well as you guys on your knives.
If Mr. Carter has a FFG knife ready to put the first edge on he may do this. Sharpen the primary edge (apex) and consider it finished because of the intended use for the knife. He will call this one bevel the primary edge and it is at an angle high enough to hold up to the intended use. Then if someone puts an additional micro-bevel on the edge the cutting performance will be degraded. Why? Because a lower angle always cuts better. Always. If the new edge apex (micro-bevel) angle is HIGHER than needed for the intended use, cutting performance will be degraded.
NOTE: My description of what Mr. Carter might do is only an assumption on my part. But it is my understanding after the experience of sending him a knife to sharpen and his comments on it and my checking out his description of one of his knives on his site. Oh yeah guess what? The knife came back very very sharp.
Murray Carter is an exceptional knife sharpener. Who knew???
It will cost almost $20 for shipping to and back but I am glad I spent the $. Couple of benifits. First is to know what a VERY sharp knife feels like and be able to use it. His comments on my edge were very informative and gave me a lot to think about. The one bad thing is it prompted me to post this and if you have read this far, sorry.
Actually, one of my reasons for sending him a knife was to get it back and get a better understanding of how to use the 3 finger test of sharpness he likes. I figured I'd have a knife that passes the test to compare with the knives I have tried the test on. I'm still at a loss about how this test will tell me how sharp a knife is. Maybe I'll figure it out one day. That's another issue and thread thank god.
Finally, one other reason I can think of to use a micro-bevel. When performing touchups it's faster to hit the edge with a few strokes at a slightly higher angle. But if the angle is already at the best angle for the intended cutting, increasing the angle for a micro-bevel will degrade cutting performance. Now here's what I believe about this. How much degredation?????? IMO a tiny micro-bevel at a slightly higher angle won't lower the cutting performance enough to matter for 99% of cutting tasks. In a laboratory performing cutting test maybe a difference can be measured. But for someone fileting a fish or cutting sticks to start the camp fire? Doubt if they will notice anything different. I know I couldn't.
One thing I forgot to mention. Different type blade steels and intended use will effect the decisions on edge angles and bevels I suppose.
Oops. I hit submit before I was finished. Almost finished though.
Last thing to consider I guess is what you use to sharpen. I free-hand and use an Edge Pro. With the EP we can put a micro-bevel on a knife that is exact as well as any other bevel. Free hand sharpening always produces at least a slight convex edge or bevel. So, the edge apex angle will always be at least a little bit higher than the angle at the top of that bevel. So, we might be able to consider the very edge apex of a convex edge a micro-bevel making it easier to touchup than one created with an EP, WE or other system with established, controlled angle capability. Again, that's another thread.
I hope what I wrote is understandable. Can't swear everything is completely correct as I'm no pro.
Jack
