deltablade
- Jul 29, 2006
I lost the medallion on this Western folder. What should I do with the inletted oval now?
What thickness do you need? A good hardware store often will have a little copper and brass sheets and rods. Online knife making supply companys also carry it. Jantz, Texas, Alpha, probably others.hoping for suggestions. I kinda like the idea of making a copper oval to fit. have no idea where to get copper sheet the same thickness
I would fill it.What should I do with the inletted oval now?
That's what I would do: Find a pre-1980 copper penny (after 1981, pennies have a core of zinc and are only clad with copper). Anneal it with a propane torch or gas stove or whatever (750°F should do it). Then hammer it to the desired thickness. Then anneal again (hammering/bending/drawing out/upsetting copper or brass will "work-harden" it), then cut it with shears or a wood chisel or whatever and file/sand to shape, then epoxy it in place.Copper is pretty soft. I wonder if you couldn't hammer it to your desired thickness. I know you can do it with brass because I've used it a ton for pins and I've peened the ends of them. Brass is just a copper alloy, right?
would a propane torch heat to 750? how would I know I reached the correct temp?That's what I would do: Find a pre-1980 copper penny (after 1981, pennies have a core of zinc and are only clad with copper). Anneal it with a propane torch or gas stove or whatever (750°F should do it). Then hammer it to the desired thickness. Then anneal again (hammering/bending/drawing out/upsetting copper or brass will "work-harden" it), then cut it with shears or a wood chisel or whatever and file/sand to shape, then epoxy it in place.
very well doneI like what you did. I had to do something similar a while back
View attachment 3092003View attachment 3092004
