Hi Dunc5 ,
I am fine , I have not heard from you in some time . In any case you asked for it , lets test peoples knowledge of comparitively modern multi tools - multi tools , tools that have been developed since Leatherman came out .
There is a multi tool that was designed that when the pliers head was partially unfolded was a working angle pliers . Similar in use to a bent nose pliers , it was the only multi tool to my knowledge capable of this use or configuration .It could be used with the pliers fully extended or as I said partially unfolded with the pliers head angled from the pliers handles .
Name the manufacturer and the model of this tool ?
If you desire I will attempt to describe the design a little better if I did not make it clear enough .
