- Sep 29, 2015
I was going to make a hidden tang Bowie as my next knife but work picked up so I haven’t had a lot of time so instead I went back to this chef’s knife that I started over a year ago but gave up on because my grinding skills weren’t quite up to putting a full flat on such a thin stock.
It is made out of O1 .062” thickness. I hardened at 1500°F soaked for 10 min and quenched in Parks 50 which I know is a little fast for O1 but that’s what I had set up. I got a Rockwell hardness of 63.5 and after two, 2 hour temperings at 400°F I ended up with a hardness of 61.
The handle material is Ironwood which I milled on a milling machine to take a curly maple insert which the photos don’t do justice to because the maple has a translucence that really doesn’t show up that well. I put on 4 coats of Tung Oil sanding after each coat. After tempering the blade had such a nice patina I just left it that way. I did grind down to fresh metal where I attached the handle. My holes on my pins aren't as clean as I would like so I may get a reamer bit instead of just using a drill bit.
I ground down to about .015” to .020” on the edge before heat treat and ground my final edge at 15° to a 3000 grit on belts and then stropped. Tried it out on a tomato and it is a very good slicer. I pretty much stole the design from a Chef's knife I bought just before I started making knifes about 2 years ago with the same geometry made out of VG-10 and I am curious to see how the plain carbon holds up against a modern stainless.
I know I need to pay more attention to finishing but this knife is for me so I didn't go for perfection. I am slowly getting there and appreciate any comments positive or negative. Thanks.
