- Sep 10, 2010
Accidentally lost everything I posted while editing the image links
Ill give a quick recap.
I've used 52100 for years for my big blades but rust has always been an issue and I've been looking for an upgrade.
I stumbled upon Nitro V which is a new steel from Aldo and decided to give it a try in my Fell Beast machetes. Nitro V is AEB-L that is modified with nitrogen and vanadium for greater toughness, edge holding, and stain resistance.
The end result is one kick ass steel that is just as tough or tougher than similar carbon steels while being completely stainless. Its also a breeze to grind and is actually easier to grind than 52100.
For testing I took a Fell Beast HT to 58-59 RC by Peter's with a spring temepered spine. Took the edge down to .018 before sharpening and the BTE thickness clocked in at .029 with an angle of about 20 degrees per side.
I started by chopping some nasty hardwoods. Went through some downed trees and then went to work on a yellow Locust tree. Locust is extremely hard and will dull a chainsaw blade. The Nitro V survived all of the hard chopping with no edge damage and would still shave after.
Next I got an old aluminum step ladder and chopped it up. I took 8-9 total chops and was able to completely chop through the material with one stroke. Zero edge damage and again it was still shaving sharp when done. Very impressive.
Finally I did the good old flex test and took this thing to 90 degrees and back a few times. No deformation and returned true.
I'll be sticking with Nitro V for my next runs. It has all the toughness and edge stability of its carbon counterparts while being stainless AND a breeze to grind
Did I mention its affordable? Theres nothing to not like about this material.
Zero edge damage after 8-9 chops
Yellow locust is some seriously nasty stuff. The machete could barley even bite into it.
Blasting through some very gnarly downed hardwood.
She can take a bend
She can take a bend
