There is a little flex in the mechanism of most folders. Tweaking the knife a few thousandths of an inch at the pivot makes a bigger difference at the tip.
Is it required to loosen the body screws first?
Nope.
One should be loosening and retightening the body screws not the pivot screws. The latter aren't cranked down hard (otherwise the knife wouldn't pivot) and should still shift at their normal position.Tried it ten different ways on my Spyderco Szabo, which I know is not a Benchmade. (Including looseningnbody screws) Szabo-10, Me-0.
Only thing I can think of is that the Szabo's pivot has a screw on each side of the pivot. I was loosening both way back out, torquing the blade and then tried tightening the presentation side first, then the clip side. No luck. Tried opposite, no luck. Blade is still scraping the clip side.
I just quickly re-read the thread, and Jimmy didn't mention loosening any screws. Most methods for centering blades that I've encountered involve leaving the pivot screws alone and loosening the body screws. I would suggest loosening the body screws just enough to take the tension off them. Leave the pivot alone.But Jimmy said to loosen the pivot screws and infact that I didn't even have to loosen the body screws.
What you are saying is that I just loosen the pivot screws a tiny bit, loosen the body screws all the way till they are about to fall out and try torquing the blade this way?
Loosening the pivot screws would defeat the point entirely. You're trying to get the pivot to shift between the scales, permanently. If the pivot's loose then it'll wiggle back and forth with no permanent affect.But Jimmy said to loosen the pivot screws and infact that I didn't even have to loosen the body screws.
Seems like this seems to be doing the trick on various models. I don't understand how it's working. What is it shifting?
More importantly will it last?
Depends on why its offcenter. If it got pulled offcenter because you were torqueing the blade then yes it will last until you torgue it hard again. If it is just offcenter for no reason then no it will not last and it will eventually find its way back to where it was before.
The blade can't be off-center for no reason--clearly there are causes the ill alignment. I should think that if re-orienting the pivot axis will bring the blade back to center, then it should last unless the tolerances of one or more elements coincide fully toward the same directional error, causing normal use and side-to-side stress to eventually return the blade to its off-centered resting point.
If the methodology for correction is achieved without loosening and retightening the body screws--essentially an extreme
prying action--then it would make sense that using one's knife as a pry-bar could cause the blade to become uncentered again.
Maybe that wasn't exactly the best wording. There is always a reason it will be off center. I was meaning if it were off center due to something other than being put together improperly or being pulled off center. Some reason other than something you can figure out. In my experience and I have a pretty good bit of it. The blade will be ever so slightly misground causing the knife to be off center if everything else is right. I have seen this with knives I have swapped the blades on. One knife might not center to save its life and if it does it just goes back. Try a new blade (from the same model obviously) and it centers up perfectly and stays there. Only thing changed was the blade. If that is the cause you are basically screwed unless you get a blade swap.
So we are trying to shift the actual pivot screws within their threads without torquing or bending the blade correct?
