- Feb 1, 2012
I DO like them! A lot of weight in the eye of that big one. It should pack quite a punch.
Those are the nicest shears I have ever seen.:thumbup:Thanks for the nice comments, appreciated
Now hammers, shovels etc are tolerated, am I a bit too far off topic with these?
Sorry no rusted up before pics. 14" long.
I've been looking for a pair of these for my wife who does a little sewing.
Funnily enough she tends to gripe a little about the vinegar & ferric chemistry station in the kitchen that usually has iron items in various states, didn't say anything when these were being cleaned.
The vendor had an even bigger pair but I thought 14" was plenty big enough!
These were very rusty but the most important bit the edge is in OK shape, a fed dings I've stoned out, no markings which I find strange.
I am also looking for a good vintage pair for my wife. I discovered that she has no idea what a really good pair is like after I used her "good pair" the other day. Ignorance is bliss if you don't know any better I suppose. I predict a well made vintage pair will be a revelation.
Truly an impressive pair! I'd love to get my hands on a set just like it.
Could you make a video making one of that slip through handles?i have the same axe head of the third photo of your first post in this thread and im struggling to make a handle for it.Made a handle for the smaller of the two wrought heads in post #73 & 78.
Started with a Rowen log & used a tiny 9oz (250g) hatchet to thin it down a bit, which it did really well!
After some draw knifing & smoothing, then B.L.O.
And draw knifed down an old cut down hickory handle for the fireman's head from post #105, it had a curved hatchet handle from the factory despite having a tapered eye rather than an "hourglass" one.....
A factory catalogue picture here, forth picture down in this thread-
http://armasblancas.mforos.com/933171/11837519-catalogo-hachas-ramon-onraita-olivo/
I decided I wanted a slip handle & like the marking left over from some of the old weathered handle. Did a little grinding on the head to improve the shape, in my eyes
Really like the fact the old head has a hole at the bottom of the eye.
Thanks for sharing your work with us,at least for me is a pleasure seeing your work.
(Excuse me for my awful english,its not my first language)
I found this hammer in my grandfather's basement that other day that looks like half of your recent pickup. It looks very much like the original handle so maybe your's is also supposed to have that orientation.
Yes im from Andalucia,i have a few olive branches that i cut a few weeks ago and i would like to do it myself and from that specific wood,im making one handle actually and i have it fitting except from the handle head,i would be very helpful if you made more photos of the process if it doesnt bother you,i can only use a rasp,an axe and a angle grinder,i dont have a spokeshave or a draw knife but if you know where to buy one here in andalucia in a physical store tell me please,also are you spanish or you are only living here?thank you for the time you spent in answering me and as i said earlier for your awesome workHi Termax, thanks & your English is fine
I wouldn't know where to start making a video...........
Are you in Spain? If so replacement "slip" handles are available from a lot of older Ferreterias, sometimes they fit, most times they need a little shaping to fit nice.
If you want to make a handle from a block or dried log it's better to split it first to get the best grain orientation, then shape it with an axe until it's a bit bigger than you want.
Use a Draw knife (a spoke shave, a coarse rasp or a disc on an Angle grinder could be used) to thin it down more.
Start at the opposite end of the handle to where you want the head to finally fit, make the head fit on that end first to get an idea what shape the handle has to be for the head to slide all the way along it, then make the handle this shape all the way along except for the other end where the head will finally fit, that has to flare out / be bigger so the head wedges.
Work slowly, try the head, remove a tiny bit more & try the head again, keep working s-l-o-w-l-y like this, it's easy to remove wood but not so easy to add it back
Finish with a rasp, scraper &/or sandpaper.
Hope that helps, I can take more pictures when I do another if that would help.
That's the way I imagined it should fit, except the eye is tapered the wrong way
As can be seen the eye is over 1/16 (2mm) bigger on the longer side so it isn't made to be mounted with angled/tapered side out, nothing to keep it on the shaft.
Not sure about the smaller marks in the eye also, they are not symmetrical one doesn't run the full width.
Of course a few minutes with a file can make the eye any shape & it'd be easy enough to alter it & mount it that way, just strange that the eye is made this way?
All these curved slip fit hatchets are freaking me out
but apart from "Ferreterias" you can find many sizes, woods and shapes of handles for your projects at two major Spanish stores (like Wallmarts in the US, these are everywhere in our country):
- Leroy Merlin
- Bauhaus
