Hi Ken,
Originally posted by Ken Cook
(If you can "freeze frame" the image as the knife is knocked from his hand, you'll notice that even after the wicked blow from the training stick, the blade is still in the locked position.)
Yes, that was my point. It didn't fail.
I duel with swords and daggers every single weekend, and my opponent never touches my blade with his unless I want him to. Ever.
Never? Ok, as you say. Accidents happen though.
As a matter of fact, I even have time to orient the blade so that I take the blow with the flat of my blade, avoiding damage to my edges.
Well, I used to practice fencing, but that was a long time ago, anyway, from what you are saying looks like you're better than your opponent. In other case you may not have that time.
how hard can it be to avoid "combat spine whacks" in an actual confrontation? Answer is... It's pretty easy.
Honestly I do not now. Because of the stress in the combat situation.
May not be a perfect example, but... I love my Desert Eagle pistol. It's a lot of fun to shoot, very accurate, and once U know how to shoot it properly it's a pure pleasure. In any caliber. Will I take it into combat? No. Even though I can shoot it quite good at the shooting range I am not sure if I can do the same in actual combat.
I screw up with shooting techniques, and it may jam. Am I willing to take that risk? No. However I'll never say that DE is a bad gun, it's a great gun. Just I know what can I do with it, and what I can not.
If you can act equally cold blooded in combat and in training, my sincere congrats. That takes a lot to achieve.
Do you slam your car into brick walls to see if it can take the stress of an actual car accident?
No, I don't(knocking on the wood), but the manufacturers do for me and you. Every single model of any car officially allowed for sale in US has to pass the safety test. Not sure about the numbers, but it MUST be more than 1. Slamming into the brick walls, and by steel blocks, etc. Why? The same, safety.
Is this reasonable? I think it is. And, please note, slamming into concrete walls is not a designed use of the car, just accidents happen unfortunately, and it doesn't necessarily mean that you have to end up dead because you slammed into the concrete wall. I bet you wouldn't throw away a chance to stay alive in that case, would you?
So, back to knives, since there are no official tests of what kind of loads and abuse/use a folding knife lock should withstand, people do that. I don't think it's surprising. Or then the manufacturer should warn against that.
If I know that knife X can't withstand spine whack I won't consider it fir combat, may be for the utility use, I know many will disagree on that one too, but it's a matter of opinion.
Of course not.
As you can see it's not that simple.
Because it would be foolish to un-necessarily "pre-stress" your "equipment." Why give it battle damage before you ever even get into battle?
Totally disagree. Take a look at aviation. Once the new model is designed they stress test it, till it falls apart. Why? So you know what it can do, find a problem(s), flaws in design, etc. Hoe else would you know?
What you are proposing is to go to the battle with what? Numbers on the paper? From what I know something like that happened already with M16 rifle if I am not mistaken, it had jamming problems, which was revealed in Vietnam? In general, any time, not well tested weapons wre used in combat that always costed lives.
Yes, I'll concede that it's <b>remotely possible</b> that your knife may take a hard blow to the spine in an actual fight. It's possible. Highly unlikely, but possible none the less.
Which is more possible, to get involved in car accident, or to receive a hard blow on the blade in a knife fight?
So accepting that possibility, why pre-stress a lock that may only stand up to ONE hard blow before you ever get to the fight?
It's not about enjoying pre stressing
First of all, where you get one blow you may get another one, then what? You deserve your fingers cut off, because you let it happen? Apply the same logic to the cars, and since you hit the wall UR better off dead?
Yet people continue to spine whack their knives.
Cars, airplanes, jet fighters, tanks, etc...
If you want to test the lock strength of your knife, then do it reasonably.
Agree, but it's very hard to define what is reasonable criteria for a combat knife. No matter how well trained you are, you can't predict everything, never.
gently apply force as if closing the knife. (without dis-engaging the lock)
Gently... I think the physics are different when the force is applied not gently, but by the impact. And in the knife fight chances are both will happen. And, again, you extrapolate. might cost dearly.
1. Get more training so that your blade spine is not such an easy target.
Well, that's useful regardless the knife used, right?
2. Buy a Balisong or a fixed blade.
Balisong is not an option here in CA, and fixed blades are problematic to carry in public... Which leaves us with the folders.
