I have never figured out how some barbers can slap a razor so fast on a hanging strap while it jumps up and down and keep an edge!!????
I just learned about stropping relatively recently and have experimented with it. I have two strops that I made myself. They are three inches wide by twelve inches long. Each has the suede side on one side and the smooth side on the other. One is charged with green compound on the sued side and the other is charged with white compound on the suede side. The one with the white compound on the suede side has .5 micron diamond paste on it. (I am not so happy with the paste and am going to go to the liquid.) I also have an old belt hanging up.
First I strop on the green a few times, then the white, then the diamond, then the plain leather. Generally speaking, using very light pressure finding the proper angle as suggested here, give good results.
However, my early experience has been with older knives that I acquired in the 90s...not of the new "super steals."
I just got a ZT 562 CF in CPM 20 V and it could shave easily out of the box. Stropping it may have dulled it a bit.
After doing some reading what may have happened is that on this knife I used the wrong angle or too much pressure.
I discovered another interesting thing in my research. It may be the case that the newer particle steels do better at slicing things such as rope if they are left at around 600 grit. No, the blade won't have the mirror finish...it may not slice paper as well...but it will do better with tougher tasks. Indeed this may be the case for all steels. I don't know.
I just purchased a PM 2 and Military in CPM 110 V, a Crooked River in CPM 30 V, as well as some less expensive knives in non-premium steels. I have not experimented with stopping the Crucible steels and I just might consider not doing so, that for those knives function may be more important than form. I can live without a mirror finish. That said, like everyone else here, it is hard to resist tinkering with our knives.
I would love to hear other's opinions about this.
Hi,Man I am struggling greatly at stropping. No matter what I do it seems to dull the edge. I’m using balsa wood and a leather strop.
My edge just almost slices phone book paper. Shouldn’t I be able to bring it back the shaving sharp with a strop? I can’t seem to get it any sharper.
Hi,Balsa wood is very soft and can mess up the edge. Better off to use (IMO) basswood. A bit stiffer than balsa and won’t give under the blade as much.
I’m still having a really hard time figuring out stropping. Maybe part of the problem is the leather on my strop but I also don’t understand the pressure thing.
A lot of people say to use really light pressure basically just the weight of the knife, but then I watch some videos like the Dutch Bushcraft Knives channel and you can see they are using quite a bit of pressure.
I guess I been stropping wrong.
I always use a dry plain leather strop; no polishing compound.
I only strop to get rid of any wire edge that may have formed when sharpening on a stone. (AKA: "Oops. I messed up")
(When I was taught how to freehand sharpen 59 or 60 years ago, it was driven into my thick skull that a wire edge was bad, and "you messed up!") (My grandfather and Great Grandfather used language somewhat stronger than "messed up". I cannot use that language here because there are women and children present with sensitive ears ... or eyes, since they are reading this, I suppose ...)
I was taught to hold the edge around 45 degrees to the strop to remove that daRn wire edge, and use enough pressure to bow the strop.
Stropping will also "fix" any rolled edge from using the knife, too. I rarely have use a stone on my blades. (and even then I use the finest grit I have, either a Arkansas stove==ne, or the unglazed ring on the bottom of an (empty) coffee mug, if I need anything coarser.)
I try to sharpen to a 15 to 20 degree inclusive angle, as I was taught all those years ago. ("You want to shave the stone! Use a low angle! I SAID A LOW ANGLE!!!! You're sharpening a knife! Not an Axe!")
(They felt a 30 - 35 degree inclusive angle was good for an axe - not a knife)
