Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Nathan the Machinist , now that you've started work on them, when do you think the NASKS will begin to ship? I figure that since you're into the project you'll have a better idea of where you stand.
I have run ops 1 and 2 on all the blanks, which is milling them into accurate blocks. We're running ops 3 and 4 on them now, which are milling those blocks from both sides with a machining center dedicated to that task. They look like knives stuck in a block. It needs a little head start on the other machines. In about one week I'll start ops 5, 6 and 7, and 8 on the new Mori. That is belly trim out, bevels one and two, and final trim out, which is four fixtures and programs in that mill all tied together.
We're running EDC scales on the Kia at the moment. That will be finished in about a week and we'll start the first of the NASK scales on it. None of the fancy stuff yet, just something to get started.
So, I'm a couple weeks away from having the first few through the entire process. At that point I'll send one to a sheath maker. After that I need to get a batch together for a heat treat, and also evaluate the sheaths before placing an order with the sheath maker. There is also a lot of antique micarta that needs sawn up, blocked out and laminated.
The first cycle on scales is run on a vacuum setup that runs on the mill that is currently running ops 3 and 4 now. That has us starting real scales production at the end of the steel milling process, around the middle of august. The first batch will hopefully be back from HT around that time frame and ready for finish grinding and tumble.
So, I'll have my NASK in a couple weeks. But production won't start to ship until late August. Not for lack of trying though, we'll have it running on three of our four machining centers (the Romi mini mill is too small to help) so we're basically maxed out on it. There is an old saying: nine men and nine women can not make one baby in one month. ...sigh...
