- Sep 6, 2014
Laurence, are those the same kind they catch on the wicked tuna fishing show?
Exactly my first thought. I love that steel.:thumbup:
😎 I trust you have a big enough saw to do that sheet? Years ago I went to having my established patterns done by Water Jet. It really saves a lot of what sanity I have left by not having to do the mind numbing bandsaw and profile grinding of several to 25 plus of the same pattern! 🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪 stay safe, have fun!
The Corsair run we did was the first time I did a batch of the same design, so I guess we have one established pattern so far😎 I trust you have a big enough saw to do that sheet? Years ago I went to having my established patterns done by Water Jet. It really saves a lot of what sanity I have left by not having to do the mind numbing bandsaw and profile grinding of several to 25 plus of the same pattern! 🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪🔪 stay safe, have fun!
Talking about water jets, how much does it cost to have a piece cut? I lost the barrel bushing tool for my Grizzly and to replace it would cost a small fortune. If I could have one cut though...
:thumbup:
I ordered 8" wide so I could use the portaband to cut it. A 48" piece of steel is awkward when it's 8" wide. The wife helped and we got it cut down so its managable. I cut a couple of small coupons to start testing out some heat treat.
How much bigger is the bushing over a standard 1911? Similar shape?
:thumbup:
Oh gotcha, there's a couple of water jet and CNC subforums in the hosted maker section that might be worth a try. If you can find an alternative way to get the compensator off, you can always send it to me and I can try to fit up a wrench that would work.
It is way too tight to take off without the wrench.
North Vader, that sounds a little kinky, but yeah, I can see that (nice press, btw)Nice! North Vader seems appropriate!
If a standard 1911 'wrench' would work, I could gift you one.It is way too tight to take off without the wrench.
See above comment...Is it the same size/Pattern as a standard 1911 Barrel Bushing?
It looks like it's different from a standard wrench in the pic, doesn't taper down as much.
