- Aug 27, 2004
Well, I received a couple Kershaw JYDII models in SG2 blade steel in the mail today from a customer with the request to anodize one blue, the other green. Then to install titanium stand offs in the rear also anodized and one of my low rider clips made to fit both JYDII models for tip up, but also to fit as needed on a Shallot, a Leek, and a Blur which were all mailed to make sure I folded the clip over for the 180`in the right spot. The clip was to be anodized blue as well.
Just like I've done a thousand times before I went through all the steps, from disassembly to individual baths progressively from bead blasting first to clean them off, followed by my multi etch, to baking soda water to neutralize the etchant to the anodizing bath with voltage for the colors selected which were blue on one set of slabs, and emerald green for the other.
I kind of wondered when I drilled and threaded these because they seemed mighty easy to thread compared to titanium and I was like what is going on? Then when the multi etch didn't bubble like I'm used to seeing I was really wondering. No big deal though or so I thought.Then I took it to the baking soda, then to the anodizing bath. First one was 28 volts for blue. First thing up was the titanium stand offs from Sheffield and no problem. Nice blue there. Then the low rider clip made to order by me out of titanium and no worries there. Nice blue on that one as well.
Moved to the first JYDII slab. Nothing! Well not true. It turned my water bath murky yellow brown like it does when you put steel in there. The longer I left it in there the worse it got. This is from corrosion. I thought to myself, hmmm. Not good! So I tried the other slab. Same thing. Then I moved to the second JYDII slabs. Same thing with both of those! Two JYDII models which I thought were ti but apparently not.
This isn't the end of it. Then out of curiosity I walked the couple hundred paces to my safe from the shop and I dug out my own JYDII models. Disassembled those and did the same steps. One of these is store bought from Spark at 1SKS, the other bought here on the forums. Neither of those anodize either! So, my question is, what gives Kershaw? I've anodized a lot of ti in the time I've been doing this. I don't know what these slabs are made of but I know what they're not. They're not titanium!
Color me surprised. These were sold as titanium to me so I'd like to know. Anyway, I've informed the customer I can't do his request. Well, not all of it. The clip and stand off part is done and colored blue and magenta for the second set of stand offs as ordered. The slabs had to be taken back to the bead blast cabinet to get the splotches off because after all the dipping they looked like crap! Thank god I was able to clean those back up because I was concerned from the looks of them. They looked pretty bad!
Anyway, that was the end of my afternoon. I thought I'd come here and write about it.
STR
STR
