- Dec 8, 2016
Nice 10! The 10 was my gateway Becker :thumbup:
Will the factory sheath insert fit into the Spec Ops sheath? Thinking of just swapping them instead of forming the Spec Ops sheath insert, I'm afraid I might blow it. [emoji21]
Thanks for the reply! Got Custom Kydex sheaths for my BK7 & BK39/9, but want to try the Spec Ops for a BK10, have been holding off on this til I could figure out for sure it will work.I wouldn't worry about it. The 10 fits into the Spec Ops nicely without any work or forming, in my experience. I have one Spec Ops sheath, and the BK10 is quite comfortable in it. Maybe a hair dryer to adjust the fit. Plus, KB factory sheath inserts are a biotch to get out AFAIK (and I've tried...) - all the ones I have (or have seen) are stitched thru a little tab on the insert. No way to get them out without doing some damage. Great looking setup, so far.
Looks like a great knife. I sound stupid asking this but I have a Spec Ops Combat Master Short and was just asking if I get this knife will it fit without any alteration to the sheath itself?I own about 8 Beckers at the moment, if my memory serves me, and all but this new 10 are stripped.
I'm almost certainly going to strip it, but like you, I do like to take a moment and enjoy a pristine, new blade.
This is actually my second 10. I still have my first, but I dislike some of the mods I did to it 5 years back. I removed the ramp, the guard, polished the flats and convexed the edge. This one is going to remain practically stock, save for the coating.
The sheath didn't come with it. It's a multicam Spec Ops Combat Master short. Just took the liner out and formed it to fit the ramp with a heatgun on low. Worked perfectly.
I am torn between the BK 16 or the BK2. I have this spec ops sheath and it needs to be filled. I recently bought the ESSE 6 cm and love the sheath it came with. I'm turned off by the BK2 weight and jack of all trades master of none title. Seems like the BK 16 is a little bit better stabber / puncturer vs BK 2 crow bar with edge.You will very likely need to remove the plastic liner (it's just a strip of velcro on the back, I just used a metal wire spatula handle to break the hold), and warm the spine side of the liner up to make room for the ramp.
Make sure not to over heat the liner, it really doesn't need much.
I meant BK10I am torn between the BK 16 or the BK2. I have this spec ops sheath and it needs to be filled. I recently bought the ESSE 6 cm and love the sheath it came with. I'm turned off by the BK2 weight and jack of all trades master of none title. Seems like the BK 16 is a little bit better stabber / puncturer vs BK 2 crow bar with edge.
Strip everything except under the handles. There is and old thread on it. I did a tutorial once upon a year.For you strippers, has anyone ever seen rust develop under the scales? I haven't done that yet to my BK5 but that was the thought that I had. I realize you can take them off and keep them oiled but if that isn't done what about rust??
Here's the thread, but the photos don't show anymore: http://www.bladeforums.com/threads/becker-handle-scales-wood-manufacturing-process.830291/Strip everything except under the handles. There is and old thread on it. I did a tutorial once upon a year.
