- Aug 8, 2008
Here is one of mine.
[video=youtube;UjK4utt-3GI]https://www.youtube.com/watch?v=UjK4utt-3GI[/video]
How did you harvest the boughs in your winter pics?Our most likely survival scenario here is exposure due to spending an unexpected night out, so staying warm/shelter is the highest priority- my smallest kits (trail running in the "summer") to my largest (snowshoeing/skiing in the backcountry) are all fire/shelter centric.
the lightest/most compact kit I've come up (trail running) with is a small fire kit (mini Bic, Sparklite, small LiveFire tin and a couple of tinder tabs), a AMK/SOL poncho in conjunction w/ a couple of small beeswax candle and a small sit pad
wouldn't be the most comfortable night out, but should be around for another day
my largest "survival kit" (dead of winter) includes a waterproof/breathable bivy, down half bag (in conjunction w/ a down parka), closed cell foam pad and a avy shovel
I've tested this setup into the single digits
I also like to carry a foam pad long enough to at least put under my butt and back when I’m lying downI found this old thread instead of starting a new one.
After watching IA woodsman's video, I put together a kit:
2x adhesive bandage
5x aquatabs
condom for holding water
Hiking Compass
Waterproof matches
toilet paper
20 feet braided 1/16 cord
Opinel No. 7
Coghlans wire saw
2x butterfly closures
Mylar blanket
key ring flashlight
waterproof container with vaseline cotton balls
This weighs 1/2 lb. I mostly scrounged what I already had; didn't go out of my way to buy smaller/lighter stuff.
Coghlans wire saw
Mylar blanket
Some backpacks have this feature built in already. Have a look at the Gregory Alpinisto, for example. I have the 35l one and there is a folded (in half) insulating pad in the back. You can take it out as a biby pad. Paired with a milar blanket (the stout kind) you will have a less misserable night if you have to tough it out. They are not as thick as a regular sleeping pad (say, RidgeRest from Thermarest), but they do their job well enough.
If your backpack has a removable back stiffener, you can try to cut to size an old pad and stuff it in this pouch (along or replacing the stiffener). Also, if the pack has a water bladder pouch (flat on the back of the pack), you can also fit it in there. The goal is to avoid having it dangling or strapped to the outside. It snags everywhere and gets damaged.
Mikel
Mikel
Replace condom with one of those small plastic shopping bags. Weighs almost nothing, packs small and is much more robust, also holds more water.
Coghlan wire saw doesn't cut well and will break almost instantly...give it a try and you'll see.
Replace mylar blanket with SOL emergency bivy. I've spent many night with it. Much warmer and durable than any mylar blanket
Mikel and Barleywino, look at "EVA foam". It's a closed cell foam that's extremely light with a high R-value. I got a small EVA pad in all my backpacks. My summer sleeping pad is 4mm thick and keeps me plenty warm in the mountains. For winter i use a 20mm EVA sleeping pad.
I will consider the bag over condom. The wire saw is a compromise and yes, I will test it. My understanding is if you turn it into a vow saw, it becomes much more effective.Replace condom with one of those small plastic shopping bags. Weighs almost nothing, packs small and is much more robust, also holds more water.
The bivy is pretty bulky, about the size of my entire kit. I'm trying to keep it pretty minimal so it actually gets carried.
I tested a snap lock bag and it held water for days without leaking.
So I use a big one wrapped up with a reusable shopping bag. And the theory is I will just carry it like a really heavy set of groceries.
As a last resort kind of thing.
I will probably always have an SAK with a saw on it. Small, but better than nothing.The opinel saw is amazing by the way. The 12 I think.
