Steel and carbides have a lot in common with cement and gravel. If you get the right mixture of cement and gravel your concrete is strong. But if you add to much gravel, there is not enough cement to keep the gravel in place and your concrete crumbles. Crucible even state in there own literature to avoid sharp radii with these high carbide tool steels. The very definition of a sharp radii is a knife edge. The quote"Tool steels are notch-sensitive materials. The presence of notches, undercuts, sharp radii, changes in section, or any geometric features may concentrate applied stress and exaggerate the material’s tendency to break." and the article.
http://www.crucible.com/eselector/general/generalpart1.html
These steels are designed for machine operations like stamping out door panels for cars out of sheet metal. Nothing even close to the angle of a knife edge is involved. At most two 90 degree angles will pass each other in close proximity and shear the sheet metal. At 90 degrees there is enough steel to keep the carbides in place and let them do there job. By all means if you consider a 90 degree angle on a knife sharp get you some s90v(funny how they even have 90 in the name) and you can saw through manila rope or what ever floats your boat until the cows come home and never have to worry about sharpening your knife again. You can also do this with a backwards hacksaw blade by the way a LOT cheaper. But if you are like me and don't even consider it a knife until you get to 15 per side, 30 degrees included or below you are best off choosing a proper knife steel. Here is a video of what happens to high carbide steels when used as a knife compared to what I consider a proper knife steel(12c27). And this is compared to s30v which was supposedly developed as a knife steel.
Now I consider 1000 strips of dirty carpet more than enough wear resistance to suit my needs. And the thing that seems to be glossed over in all these "super steel" comparisons is that you can't hone them. You can take that 12c27 after 1000 strips cut of dirty carpet and run it across a steel for about 10 seconds and your razor edge is back. If you try to hone these "super steels" all you do is move the carbides around further weakening or destroying what is all ready a pitifully weak edge. You have to resharpen them which takes significantly more time. When you sharpen these "super steels" to any angle even approaching what I consider a knife edge what you end up with is a bunch of loose or barely hanging on carbides on the edge. And just like loose gravel in your driveway when you step on it any pressure moves them out of the way. And your razor sharp edge goes away. So I implore American knife makers to get out of the gravel, stop trying to put a square peg in a round hole and start making knives out of proper knife steels again. I shouldn't have to buy a Chinese knife to get a decent steel.
