The BT6 for sure... specs?
Ski
That particular and currently still the only BT6 Proto Camp Knife is made out of 3/16 CPM3V with a full flat grind and distal taper from plunge to tip. It also sports a tapered tang and maroon linen micarta handles. Full Flat grind that transitions right into a zero convex edge, OAL=11 3/4, Blade=6, Weight=8.8oz.
I envisioned it to be a mid-sized featherweight camp knife that will slice and dice for kitchen duty and still be robust enough to do some light chopping and finer woodcraft type work.
I'm going with the extremes here.
I'm really liking the Pikal and Hawkbill EDC.
Then I am really hoping for a large chopper. Something like a bolo machete or golok but a little thicker for chopping harder material than vines and light vegetation.
Finger crossed.
Good to see you stopping by bro! The Tigress is 18" OAL with a 12 1/4" Blade. It has a slight forward rake more like a khuk vs a straighter or sweeping golok like blade. Thickness is right around .200 so it is still quite a bit more stout than a machete. I will be testing her out real soon. If all goes well I may have some action vids of it going through 2X4s, water bottles, and whatever else I have around to chop
