KnuckleDownKnives
Time to make the doughnuts..
- Feb 12, 2015
Hi all. I asked about this motor quite a while back and now that i have a 3hp VFD running one of my grinders, and in the process of running power in my new shop, I'm thinking of using this motor if it's rated for what I'd like to use it for. I know it's not a TEFC, but an internally cooled motor, and I think i have a way so that isn't an issue. If i use my grinder VFD to run this is this motor ok to use at lower RPM's so I don't burn out the wiring? I want to use it to make a disc grinder. For the cooling, my plan would be to mount it to my work bench, build an enclosure around the motor with a hole cut into the bench top and large PVC piping under the bench going to a "clean" area of the shop for clean air for it to cool itself. I know this isn't ideal, but I have everything I need to do this except the disc and rest.
