Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
410 ?? The free machining grade 416 is often used for bolsters and should be easier to find at knife part suppliers.Should be easier to find than 1/8" 410.
Hi Guys,
Thanks for the info. even though it wasn't me who asked the question.....
Got a couple of questions (OK 3) also:
Can anyone tell the color or appearance difference between 416 and 410...say I use 416 pin material and 410 for bolsters and liners?....I can't tell but that is just me and the pins need to "disappear" after peening and finishing.
Will 416 (bolster material) solder to 410 liners as well as 410 to 410?
Does anyone have a source for 410 pin material in 1/16" and 3/32" diameter?
I have tried to Google and not found it those or wire sizes that might be similar.
Thank-you!
I use 416 pins through 410 bolsters with no problems, I can't see them in there. I also have had no problems soldering 416 t0 410. It's basicly the same stuff. I think 410 makes a better bolster because it comes harder and finishes so nice. It is also pretty flat and doesn't need ground, just wipe it on a surface plate.Hi Guys,
Thank-you!
I have always soldered bolsters on, The secret is to get everything flat and straight then tin the bolsters and liners. Kerry done a thread on how I do it, maybe he could put up a link.Thanks also to Tony and to Mike.
Mike, I'm real glad that 410 is a new item in the BigBook.....I scoured last year's and the online, and would take an oath they didn't have it in precision ground or otherwise last year.....
I did just order some from Slice of Stainless...by phone...call me old fashioned..I can hopefully tell more about someone talking with them so like to call the first time doing business with someone.
I bought more than I should have and I asked them to cut in smaller pieces..
It's 4:45 pm, 5-3-07 and they will cut it and still ship tomorrow.....That is service!
Tony, Thank you for your help I have plenty of 416 pin material and will practice up my soldering skills....
If I may ask one more question, do you solder all your bolsters to sheet, even
double bolstered knives....or do you sometimes mill the double bolstered liner/bolster combination from a thicker piece of 410 or 416?
Thank-you,
