- Feb 20, 2010
I wanted to know the general feeling about 1085 steel. How fast will is rust?, durablilty?, edge retention?
From my point of view a blade must not stay shiny silver clean. A carbon blade will and should get gray or black through use. That been said:
Once i wanted to teach my wife about proper knife care considering carbon blades. The objekt was a small kitchen knife, made from 075 carbon stell, should be something may be called 1075.
I cut into an apple with it and let it lay.
The only thing, happening was a light gray tone on the blade. The way to let it rust, real red rust, was to let it wet in the ditch.
But, you have to look very very long for this.
I never oil my carbon blades.
What was about to learn: Carbonblades are not that much rust sensitive as often told.
Keep it dry and more or less clean. Is just enough. You get a patina, that is all.
I live in central europe.
The Ka-bar heavy bowie came to my mind too. I found this steel grade to be the best choice for a medium chopping camp knife. Balenced in edge retention and toughness.
1085 is tougher than 1095, but has lower edge retention.
It's carbon steel. It will rust if not protected. All steel was carbon steel until about 90 years ago. Our forebears seem to have made out with it OK.
1085...{}...has lower edge retention.
I think that should be qualified slightly to say that 1085 could have less edge retention in abrasive mediums, and only if the 1095 managed to get an optimal heat treat, which could very well turn the 1095 into something considerably less than the 1080/85
I think that 1075/1080 still tend to have some lathe martensite, which could help them hold a finer edge under a little more distress than 1095, which I think is entirely carbides, so the 1080 could tend to hold a finer edge longer under certain conditions, along with a bit of added toughness, and a better chance of an optimal heat treat. While this is a bit of conjecture, I don't worry a bit about a bit lower carbon content.
Of course, I don't know that there would be much of anyone who could tell the difference in actual use, at least not without the same job and two optimized blades.
Can anyone tell me why Becker stoped using 0170-06 c in there knives
Well that is an interesting data point. I have knives of 1080 and 1095, and haven't noticed a difference, though I have not put them side by side on the same test because they are different profiles. I guess I did once, but the 1095 stank in comparison, cutting rope, and I assumed it was a soft blade.
ETA, Knarfeng, were the two knives the same RC and geometry, just out of curiosity? Or just two factory blades? I am just wondering if you were doing it with two 'mules' or similiar, and how much was attributable to other factors.
