XHP will give you mediocre results if you drive it to really high heat and quench it. I've got some plane irons that seem suitably hard, but knives are hard to get enough heat and I've ended up with usable knives, but the hardness is by perception in the high 50s.
(plane irons have a much smaller area to heat, so finding concentrated heat isn't as difficult)
I sent an underheated sample to larrin thinking maybe it didn't need all of the heat that made a (subjectively) better and much harder plane iron since I'm not dissolving chromium. Bad bet. Came back around 57.3 hardness with 8.something of toughness by his charts.
With some additional support to the apex and a thin grind, the test knife I made out of it works great.
Did I mention? XHP is expensive.
the harder plane irons that I've made have planed head to head with Lee Valley's PM V11 to 95% of the distance that V11 irons plane. they are at the top of XHPs range, which probably has something to do with it. The softer samples wouldn't get there, but I haven't made a plane iron with these softer type samples.
what i'm giving you for this is cowboy advice, not proper heat treatment - but what I did is this for the harder plane irons - bar stock, right out of the box, heat to a very high temperature as quickly as possible. you'll have trouble getting past the 1950 or so that's suggested, and this needs to happen in like a minute or two, not 20.
Quench in oil.
I made this tiny test mule a couple of years ago and it's also higher hardness than the sample that I sent, but it's not close to (by my perception) getting where Lee Valley gets their irons after temper (63 hardness). It's thin and will slice a long time without chipping. when a knife is either iffy or a bit soft and getting a really fine edge is a burden, I will generally used a stitched wheel to buff off the apex just a little bit and then it will hold up fine, and the buffer will get rid of the burr with an efficiency that you couldn't match by hand.
XHP test mule
AEB-L will also cowboy harden like this, but you need high heat very fast. It'll also get into the high 80s after temper - you have to be willing to waste some time because it'll get past where you want it to be hardness wise and incremental tempering is necessary to find the point where it stops chipping. Buffer trick applies - I used this to gauge the wear resistance of AEB-L for planing wood (very good - hardness from the cowboy hardening comes up short, though) and haven't made a knife from it. It's far harder than saw temper ...far harder......in high quality 1095 spring, which is 52. It's just not 60 or above where you can start to get nice burr characteristics and easy sharpening and edge strength.
