1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Week 4 of the BladeForums 20th Anniversary Year of Giveaways is live!
    Click here to enter the drawing for your chance to win a Benchmade Limited Edition 319DLC-1801 Proper, or Bladeforums.com swag or memberships!
    Be sure to read the rules before entering, and help us decide next week's giveaway by hitting the poll in that thread! Entries close at midnight, Saturday January 26!
    Questions? Comments? Post in the discussion thread here
  3. Matt "Charlie Mike" Freeman passed away unexpectedly last weekend. We have various threads posted in both the General & Community forums, please share your memories:
    RIP Charlie Mike
    A Go Fund Me has been started to help cover his funeral expenses: https://www.gofundme.com/cmftw-for-matt-f
1st Attempt at San Mai Billet
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Ken H>, Jan 12, 2019.
  1. Ken H>
    Ken H>
    Dec 31, 2011
    OK, here' my first attempt at a San Mai billet. It's got a .093" thick 15N20 (high carbon) with a .100" layer of mild steel on outside. Clamped in vise, stick welded all way around, put in forge got hot (bright orange) and started pecking away. The trick seems to be light steady taps, not hard whams. The black is the 15N20 core that's been etched, with the whitish part the mild steel outside. Best I can tell there are no delaminations visible. I'll most likely cut this up looking for delams inside rather than make a blade from it. I didn't take photos of making the billet because I didn't expect it to turn out this good.
    [​IMG]
    This is the top edge - the core seems to be fairly well centered and no delams visible on top.
    [​IMG]
    Michael.Drinkwine and Willie71 like this.
  2. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    Only way to know is to cut a knife profile out of it and see if the center welded. I would be concerned about "Bright Orange". You need to weld at yellow heat. Drawing is ar orange heat. Colors are based on the observer, and may appear different depending on the smith and the light, so you may be fine.
    I like to stick a piece of coat hanger in the forge, pull it out after a few seconds and stick it in some borax, then out it back in and push it against the surface of the billet. If it is at welding temp, the wire will stick. Just twist it to remove and it will pop off.
    Ken H>, Matt R and bike4fun919 like this.
  3. Ken H>
    Ken H>
    Dec 31, 2011
    Perhaps "bright orange" isn't the right color I actually saw - it was more to the point of next color would have been whitish looking. It's hard to determine color in sunshine. With the TC tip right at the edge of the insulation in forge the temp was around 2200°F. If I pushed the tip more toward the center of forge the temp is over 2400°F. Moving billet around inside forge to get an even color over the total billet I figure the temp was in the +2200F range. I should have tried that coat hanger trick - I'll do that next time.
    I had planned to cut up the billet looking for delams, but perhaps profiling a blade would would be just as good. "IF" it does happen to be clear of delams no reason it wouldn't make a decent blade.
  4. weo
    weo KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    824
    Sep 21, 2014
    Hi Ken. Make sure you post a picture.
    I'm curious to the contrast between the mild steel and 15N20. I did a santoku a year ago out of 3 layers (O1 core, 15N20 and mild steel on the outside) and there isn't much contrast between the mild and 15N20. [​IMG][​IMG]
    I'm not sure if I didn't forge it out enough so I ground through the all the mild, did I forge it off center, or if I didn't sand it enough before etching to get a good contrast, or if I sanded it too fine before etching, or did I sand it too much after etching, or....
    If I'm remembering correctly, it's likely that I didn't forge the billet thin enough and ground through most of the mild.
    Ken H> likes this.
  5. Ken H>
    Ken H>
    Dec 31, 2011
    You can see the contrast in my profile photo. Remember, this billet is NOT HT'd yet and the nice dark black of the 15N20 would come off pretty easy I'd expect. I'm in the process of profiling out a blade now. Once I get it worked up I'll be etching the edges looking for any delams that might be exposed.
    That blade looks good. I see what you mean by sanding too much of mild steel away, it's left islands of cladding - I like it. BTW, what handle wood is that? My wife LOVES the spalted woods. Of course, each new wood (or new knife I make for her) becomes her favorite.... until the next knife anyway. {g}
  6. Ken H>
    Ken H>
    Dec 31, 2011
    OK, I got the profiled blade shaped, ground, and etched. With all the grinding I did no delams showed up so I'm pretty happy with my first San Mai attempt. Now to HT, finish grinds and put handle on knife. With the 15N20 core it should work good, but boy I'll bet that mild steel cladding will rust just looking at it! My 2nd attempt on a gut hook, my first was in the first year of making knives and didn't really like putting them in. Still don't, but wanted to try again.
    [​IMG]
    Coy Ranch likes this.
  7. weo
    824
    Sep 21, 2014
    It's the same wood as all but one of my knives, spalted maple from my trees.
    The handle is one of the reasons why I haven't tried to redo the finish
    Ken H> likes this.
  8. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    The mild steel cladding wil not rust any easier than the 15N20. It takes a lot moren than 2% nickel to become rustproof.
    Ken H> likes this.
  9. Ken H>
    Ken H>
    Dec 31, 2011
    Thanks for info Stacy - I normally work with SS and forget how quickly carbon steel can rust. It just seemed like the mild steel cladding was rusting so fast. Is there a trick to getting that black oxide coating on the 15N20 to stay black with use? I've not HT'd the blade yet so maybe it will be better after HT?
    Thanks again for the help on this forum.
    Ken H>
  10. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    Glad it welded up fully.
    The black is just a surface oxide. If the knife is sanded, buffed, or used … it will rub off.
    Ken H> likes this.
  11. weo
    824
    Sep 21, 2014
    That reminds me of a question I've been wanting to try out, but as it's now been almost a year since I've been able to do anything in the shop....
    Because the oxide on sanded/buffed steel gest rubbed off quicker, is there a rougher grit finish that will still allow the oxides to wipe off the 15N20 easily but not the rest? Especially on San Mai knives where you can't etch to get topography like on standard damascus.
    Thanks
    Ken H> likes this.
  12. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    THe best way to keep a black edge or other area is to sand and finish the whole knife and then give it a quick etch. Rinse and neutralize well and then carefully hand buff only the part you want silvery with something like the 3M pink sheets, or 0000 steel wool.
    Any spots on the dark areas that need touching up in the future can be quickly done with a Q-tip and FC. Remember to wash off the FC and neutralize before oil again.
    Ken H> likes this.
Share This Page
