I finally did it! My first Damascus billet. It is low 10 layer count. I welded up one billet using 6 layers, alternating 1.125" wide by 4" long of 15N20 and 1075 with .003" nickel between layers. I ground clean both sides of steel, clamped tight in vise and welded the end corners with a rod welded to one end. Soaked stack edge with WD40 (just sounded good), put in forge and heated to a dull red, put small amount of anhydrous borax on edges to cover good, put back in forge and let soak for a few minutes until it looked really hot (about 2100F per indicator), pulled out and used my "Baking Soda" (arm & hammer) power to forge. Repeated a couple of times and it's looking pretty good.
It welded up about 1"X1"X3", then drawn out to 1-1/2" X 7" and about .150" thick. After grinding on SGA it wound up being .115". Here it is with a small bevel and lightly etched in FC to show layers.
While it was in a square billet I thought about forging a slight rounded shape, then doing a twist. Would the nickel between the layers of steel increase a chance of delamination with the twist?
