Just read a study where 3 carbon steels were compared to a stainless steel blade, all the same geometry, same sharpness, and same hardness. The stainless blade did better than the other three blades, doing the same cutting, with respect to edge retention. All three carbon steel blades were forged. The stainless blade was ground from stock received from the steel supplier.
This study shows that the old common knowledge about stainless steels not holding an edge as long as carbon steel isn't true. It also shows the common knowledge about stainless not getting as sharp as carbon steel is also not true. The forging of the carbon steels is only mentioned here because it was in the study. There is not enough evidence to show that had anything to do with the results.
Most members here probably already knew this, but the old myths still lurk in dark corners even here.
