You know what, I think I know what they're doing.
I think they take a sheet of finished prepreg and lay a new wetted out layer of carbon fiber on top that they can apply peel ply on. That would explain it, I can't say that's what they are doing proof positive, but that could definitely explain it. Similar to what they were doing with carbon fiber over g10, but carbon fiber over carbon fiber.
It's not as homogeneous as an unembellished sheet, but I guess as long as it's carbon fiber and carbon fiber it's a nitpick. Epoxies are strong enough that I'm sure it won't be an issue.
Let's not get all bogged down with how Carbon Fiber is made.Well I mean, isn’t all carbon fiber just glued together?
I confirm that it's solid carbon fiber. Because when you take the scales off, you can see the inside checker-board CF pattern.
If you decide to sand, wear a face mask please.
I will try and take a photo through my triplet if that will sate your disbelief. It's not even up for question anymore, even under 10x it's clear as day these are two different materials.
I'm no expert, so I just pose the question. Would the glue line not be different to the actual carbon fiber and glue mixture of a solid piece? Without having the fibres continue all the way through as one, does this not make it something other than solid technically speaking?No. It's clear that they used two CF pieces and glued them together. I assume, since it is easier to cut out the liner room in one piece, and then glue a "cover" on top of that piece.
Now: "Carbon Fiber" by definition is Carbon-Fiber reinforced polymer, layers of carbon fiber glued with a plastic resin (Epoxy or something else) and then possibly baked. If they used the same resin to glue together the above two pieces (maybe even baked it?), it counts as "solid Carbon Fiber scale" in my book, even if you see the glue line. Until we know that they didn't do this, I will believe Spyderco's advertisement.
Roland.
