I'm not sure if people care about making a karambit razor sharp or not. The man I trained with, who popularized the karambit in North America, probably cares as he trains to fight with the karambit. I think all blades that are designed to slice (not just pierce with the tip) should be sharp. For the record, I only did a very small amount of training with Tarani and it wasn't even with blades.
Any time I have a hard time raising a burr and I know I need to remove a lot of metal, I do one of two things. Or both.
1. Use a more abrasive media. (Low grit stone or belt)
2. Go to a powered (motorized) system.
I would be inclined to use low grit (like 80) sandpaper, or a very coarse sharpening stone on the karambit. If you do, please keep in mind that it's much easier to cosmetically scratch your blade with coarse stones. If you care about looks a lot, you should tape up your blade pretty thoroughly before staring with a coarse stone. I'm actually not sure what kind of motorized system I would try on a karambit, as belts aren't very good at reverse curves.
The corner of a very coarse stone is probably your best bet. Or sandpaper wrapped around a dowel, or maybe wrapped around a sharpmaker rod.
As someone else said, you might be clogging up the corners of your stones pretty good with the amount of sharpening you have been doing. I would recommend using a powdered cleanser and a toothbrush to clean your stones off. I like Bar Keeper's Friend because it has oxalic acid in it, which "eats" steel residue, so it gets sharpening stones really clean. You can use almost any kind though: Comet or something like that will probably do a nice job. If they are clogged, when you unclog them, they should cut faster.
Finally, when removing a lot of metal, I definitely recommend switch sides after a decent amount of grinding. For me, on stones, I usually go for about a minute or so, and then switch. You could probably go for longer; maybe 2 to 3 minutes, and then switch. As the previous poster said, you can off-center your edge if you grind too much on one side.
I'm happy to hear that you have enjoyed the Seven Secrets; I hoped it would help people out.
Good luck with your project. Be sure to let us know how you progress.
Brian.
