- May 14, 2011
Barry, my sucker rod wood #86 also weighs 3.7 oz. on my postal scale.
Great Photo.
can always put those two bladers on a diet! mine is about to return from a spa!
excellent, and I had a blade deleted! should put that baby around 2.9-3.0 oz
Jack's and mine headed to the same locale, mine arrived back today and I am totally impressed I love the transformation, don't get me wrong, I love the stock two blade was well. The pinchability is a plus on the single blade and is obviously different "in pocket". Rock solid and centered blade along with factory like finishVery very pleased with the craftsmanship jsdidtin executed on the blade delete. Thank you!!!
Thanks Jack, I love the single blade. He does flawless work, you'll be pleased
Jack's and mine headed to the same locale, mine arrived back today and I am totally impressed I love the transformation, don't get me wrong, I love the stock two blade was well. The pinchability is a plus on the single blade and is obviously different "in pocket". Rock solid and centered blade along with factory like finishVery very pleased with the craftsmanship jsdistin executed on the blade delete. Thank you!!!
He aced it! Whew, sure is tempting me to do that to the bloodwood. Or the canvas and then polish it, possibly with domed brass pins just to be weird and tactile.
that is a beaut! unfortunately, the storm threw mine off. Im almost tempted to buy his other blade deleted 86
Thanks guys I appreciate the kind words. I hope yours does come soon Jack, I think you’ll be pleased, I reused the original pins I could which included both the center pins so the walk and talk is near identical.
The pins on these are the tightest I’ve seen so far, I don’t think you’d be able to do much without drilling out the holes and that probably wouldn’t do anything anyway and the one time I tried the bit bound up in th spring and broke off and heated the spring enough to blue it.Jack, who's deleting your blade? I've been thinking about doing one myself, and then using 3/32" pin stock to see if the pull will firm up at all.
The pins on these are the tightest I’ve seen so far, I don’t think you’d be able to do much without drilling out the holes and that probably wouldn’t do anything anyway and the one time I tried the bit bound up in the spring and broke off and heated the spring enough to blue it.
