Got mine today as well, both tanto and drop point. Came pretty sharp, but suffers from the usual uneven grind issue, especially on the drop point one. Had to reprofile the edge to make it even right outta box, but i now have a nice mirror edge on it. Other than bad edge grind, the fit and finish are great. The AUS10A is surprisingly wear resistance based on my anecdotal sharpening experience. Took quite a bit of time to reprofile the edge despite using diamond stones.
This is my favorite new designs of 2020. My only gripe is that the scale is a bit too thin for my liking and the thinness can be a hot spot when using it for long. I felt that when stropping the blade.
I hope it does well and Cold Steel can make a higher end version with thicker contoured scale and more premium steel. would be much more comfortable if the handle is at least as thick as the lawman.
Side note - the blade to handle ratio is excellent. It has almost the same blade length as the Ultimate Hunter but the handle is about 1/3 to 1/2 inch shorter. This is very efficient design, I always find that the Ultimate Hunter handle is too long for the blade.
