- Dec 20, 2005
I've had 2 electric motors from Harborfreight (1HP, TEFC, 1750RPM, 110V) crap out on me. They suddenly just stopped working. Anyone else had this problem?
They advertise it as an electric motor that can be "continuously" run. I ran it for about 1 hour grinding a large bowie and a small hunter, when it stopped. My first motor, the same specs, stopped after about an hour of continuous use. I've had both for several months before this happened. If I just use it for 30 minutes, and then switch it off -it seems like it can run forever. It's when I run it for long periods and really push a blade into the platen when I hear the motor slow and suddenly stop.
Should I step up to a 1.5HP or 2HP motor using 220V? Am I being too hard on the motor? Is there anyway I can troubleshoot this myself to figure out what keeps causing these failures? Maybe hook up an ohm meter and check out the resistance? I tried the reset switch on the side, but it doesn't do anything.
Any advice would be appreciated! I'm tired of killing motors, they cost quite a lot to replace! :thumbup:
