3/4 HP Disc Grinder?
Hi,
I found a good deal on a lesson 3/4 HP motor, and was hoping to use it for a disc grinder. I know that 1 hp is a very common motor size for a disc grinder, so wanted to make sure the 3/4 wouldn't be too underpowered. I have a single speed 2x72 I built, but am hoping to use the disc grinder with variable speed to finish bevels from a 120 grit belt finish and to flatten handles/guard material. Will I be disappointed with 3/4 HP?
Thanks
hell, the 1/3hp setup I just built has more than enough power for my needs. if anything 3/4 might be slightly overkill (not that that's an issue ;))
I agree, I have two 1/2HP disc grinders that work great. The 3/4HP is for the Nielsen system.
Far more important than the HP is VFD reversible. The good thing is that sub-HP VFDs can often be found for cheap. Same for sub-HP 3ph motors.
DC and a DC speed control works, too.
