3-in-1 Dry Lube Can?
WD-40 is not designed to lubricate at all (the WD stands for water displacement!).
After using WD40 you should always followup with a lubricant.
Yeah, sorry, I didn't make myself very clear in my first post :( After wd-40 I usually use 3-in1 oil or Miltec to lube/rustproof. I like 3-in-1 because it's cheap, and I like Miltec because it doesn't collect dirt & dust. I guess I was really wondering if this high-performance dry lube would be the best of both worlds?
That's beyond my knowledge level. Today, you need a degree in chemistry to understand how all these specialized products work and what works best where.
Anyone ever used it? Apperently its new, its partway down this page:
http://www.wd40.com/Brands/3in1pro.html
I like to use wd-40 to clean out knives/tools, but it doesn't seem to lubricate/rustproof for very long. Would this do that better?
Howdy,
I looked up the MSDS for 3-in-one dry lube on the WD40 website.
In plain English, this is the composition: It is mostly heptane (read lighter fluid), about 5% Isopar E (read kerosene), about 1.5% oil and teflon.
The teflon should lubricate well and may last longer than 3-in-one oil. It will definitely lubricate better than just WD-40, which, as j22knife pointed out, is not designed to lubricate at all.
However, there is no rust preventative in the 3-in-one dry lube. So it will not protect from rust.
Thanks Knarfeng for the "plain English"! You answered my question- it's not what I'm looking for.
