- Jun 9, 2010
Hola,
I have seen plenty of derogatory comments directed at people who admit to using angle grinders here on the forums, and yet I know plenty of people here still use them. I use them, because they work and they work well. But, like any piece of equipment found in a shop, angle grinders can be dangerous if not taken care of and used properly.
I just wanted to share a good little article I found about some of the most common safety hazards, and some potential reasons these hazard could arise. In addition, the article suggests ways to combat these hazards. Most of their numbers are backed by outside sources.
The article in its entirety. http://www.nationalnewstoday.com/in...ive-blades-diamond-blades-that-break-kill.php
The biggest favor you can do yourself in my opinion is switch to a diamond blade. I've been fighting fire for about three years now, and some neighboring departments still have K12 saws (big ole saws with 12-14 inch blades) that still have abrasive blades on them... no thanks. Mine switched to diamond years ago. The dangers of abrasive blade shattering has been well documented, so I sure don't want a 14 incher to go.
Can't say I've responded to any emergencies caused by angle grinders, but I have been to two chainsaw kickback calls which is related in the sense of a tool kicking off of something else.
Have fun. :thumbup:
In 2008, nearly 25,000 were injured nationwide while using angle grinders (U.S. Consumer Product Safety Commission). The majority of these injuries occur from an abrasive blade shattering, diamond-blade segment loss, or the angle grinder kicking back. Any one of these scenarios is potentially fatal, with a high percentage of non-fatal injuries requiring hospitalization. Let’s take a closer look at each of these individually. While nothing is one-hundred percent preventable, there are steps that can be taken to drastically reduce the possibility of injury.
Abrasive blade shattering
An incredibly dangerous occurrence, the easiest way to prevent this from happening is simply not use these silicon-carbide blades, often referred to as throwaway blades. Silicon-carbide blades are 6.3 times more likely to end in death than a diamond-blade should they shatter. If it’s not curtains, the chances the injury will be serious enough to require hospitalization is 13 times greater. Opt instead for a diamond blade.
If you still choose to run an abrasive, make sure the blade being used has not been damaged (cracking, chipping, exposure to water, etc.). You should never reuse the same blade on different days. It is important to be positive you are not running the blade at a higher RPM than recommended, and never tilt the saw to the left or right while cutting. Pay very close attention while using these blades.
Diamond-blade segment loss
Here a far less dangerous product but none the less still deadly. Diamond blade breakage is far less common than an abrasive blade shattering, diamond-blades can lose a section causing injury as well and the results are extremely deadly. Sixty percent of the time a section of diamond-blade broke off and struck an operator, death ensued (OSHA). The remaining 40% caused serious injuries requiring hospitalization.
The best way to minimize these accidents is to use a blade with a strong weld, or no weld at all. These are called Safety Blades (http://projectvbp.com/documents/index.html). This is a process by which the diamond sections are attached to the steel core without the need for a weld. Since the main reasons for segment loss are defective welds, or weakened welds due to overheating, this type of blade virtually eliminates the chances this can occur.
Grinder kicking back
Occupational Safety and Hazards Administration (OSHA) statistics show a 20% fatality rate for injuries resulting from grinder or saw kickbacks. The other 80% of injuries were serious enough to require hospitalization.
One of the main causes of injuries from kick back is operator fatigue. When the operator becomes tired, they generally stand closer to the blade, trying to use their body weight for stability. Another reason is an incorrect blade for the task. The cut begins to take too long, heating up the blade, and a tired operator starts leaning closer. When the overheated blade begins to wobble it will kick back, and the proximity of the operator means a higher risk of injury.
Angle grinders can be one of the most useful tools, but their safety drawbacks need to be addressed and taken into account. A good tool is one that allows you to go home at night in one piece. Click here for more tips on angle grinder safety.
Have fun. :thumbup:
