Josh K
Platinum Member
- Sep 29, 2008
Sebenzas are not supposed to need loktite by design. If it needs loktite to stay together, CRK screwed up. Chris Reeve was proud of the fact the Sebenza didn't need screw glue to keep it together...it's kind of a tool and die maker thing.
Easier to go right to the source. Note that while I’ve only quoted a small portion it’s well worth a read. It could have been written yesterday instead of ten years ago.
All screws should be snugly tightened down onto the pins there is no need for Loctite, nor is it necessary to super-torque the screws down. (Exception - see comments on Umnumzaan pivot.)
· With the Umnumzaan, Loctite is necessary in the pivot assembly. The threads in this assembly are machined to very close tolerance; the drop of Loctite gives additional rigidity. It also prevents the pivot from backing off. Loctite is an accepted engineering screw retention substance used in a wide variety of industrial applications including medical, electronics, automotive and aerospace. We do not glue our knives together. Extensive thought went into all aspects of this pivot assembly it did not happen by accident.
