You many already be aware of these products but I just discovered a fix for an annoyance and wanted to share.
I did have this one annoying blade that was a fingerprint magnet ... that is ... until I buffed it out with 3M Scotchbrite pads.
Took about 5 minutes. It's a softer satin now - but does show a scratch pattern if inspected more closely.
So see the ***Caution below.
I used Green then Light Grey then white.
I suspect the 3M Polishing Papers could bring it back up closer to a mirror finish but I haven't yet tried them. Maybe later today.
***Caution!
I'm not recommending this to anyone that's not sure what these pads can do ... so if you're not sure then please do a test on something that doesn't matter to you.
So, disclaimer out of the way ...
I love these Scotchbrite pads.
For one reason, In my opinion, the Light Grey and white are the only logical substitute for #0000 Steel wool.
Tiny metal droppings be gone forever!
All of my steel wool has been in the garage since I discovered Scotchbrite pads about 10 yrs. ago.
Grit Chart:
SCOTCHBRITE GRIT CHART (courtesy of Charlest)
3M Scotch Brite Nylon Pads:
7445 - White pad, called Light Duty Cleansing - (1000) 1200-1500 grit
7448 - Light Grey, called Ultra Fine Hand - (600-800) 800 grit.
6448 - Green (?), called Light Duty Hand Pad - (600) 600 grit
7447 - Maroon pad, called General Purpose Hand - (320-400) 320 grit
6444 - Brown pad, called Extra Duty Hand - (280-320) 240 grit
7446 - Dark Grey pad, called Blending Pad (180-220) 150 grit
7440 - Tan pad, called Heavy Duty Hand Pad - (120-150) 60(?)
Green Scotch Brite is available EVERYWHERE. It's 600 grit.
Blue Scotch-Brite is considered to be about 1000 grit.
(The value inside the parentheses is directly from 3M.)
3M Chart
An other "Official" 3M pamphlet but it doesn't list the Green and Blue
And then there are the 3M polishing papers which are an other really cool product.
I happen to have them in 400, 800, 1200, 4000 grit which were the grits recommend to me for polishing stainless steel guitar frets.
I discovered these after getting into stainless steel frets for my guitars, a few yrs. ago, and wanting to polish the frets to a finer soft mirror like finish.
They get to feeling like glass. Greasy and slippery - nicer for bending notes.
www.stewmac.com
SO, I may go a bit higher with the scratch pattern on that blade. later today using the polishing papers,
but for now I'm happy with it.
***Caution!
Grit Chart:
3M Chart
3M Flexible Polishing Papers - StewMac
Strong micro-grit finishing papers, so flexible you can use them like cloth, wet or dry!
